Neat little trick - rb25 water cooling for turbochargers
sepulchralx
Car: 240sx
I used 5/16" female to male flare adapters and they thread perfectly into the water port on the RB25DET block and into the water ports on my GT3582R. I used a tiny amount of teflon tape, and they don't leak a bit.
So now I'm running steel brake lines prebent as my water lines, i plan on getting some SS goodrich stainless brake lines. You'll want to run 5/16" brake lines, the diameter of the hose is large enough that you will supply enough coolant to your chra. Pretty cheap, cost effective way of cooling your turbo (considering there are no top mount RB oil/water line kits available, though I was quoted $350 by a guy on freshalloy.)
So including the oil feed line I spent a total of $80 on lines for my turbo, pretty tight if you don't care how your line set up looks and if you favor HARD LINES
PS (i removed zip ties after adhesive stuck and i used safety wire every 3" to hold heat wrap on.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
what mount kit is that?
sepulchralx
Car: 240sx
JGY/Top Hat
Its trash. Don't ever buy it!
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
+1 for hard lines -1 for abs
Which top mount will you be using?
sepulchralx
Car: 240sx
Fibre guy wrote:+1 for hard lines -1 for abs
Its the gt3582r turbo.. I'm already using it, the lines work just fine and dont leak at all. I dont have to ziptie them out of the way or worry about them hitting anything because the fact that they're hard..
-1 for abs?
Fibre guy
scratch that....A quick look and i thought it was abs brake master...
rb26tommy
Car: nissan 240sx s14 rb26dett
it look like top hat mounts. it has a c logo on it. i have those mount on my rb26 240sx for about 4 years now and they are great. but that is my opinion
sepulchralx
Car: 240sx
rb26tommy wrote:it look like top hat mounts. it has a c logo on it. i have those mount on my rb26 240sx for about 4 years now and they are great. but that is my opinion
Well when i lowered my engine on the mounts i watched as the mount extensions bent which was pretty s***ty. Then my transmission mount holes didnt line up at all i had to re drill them.
BHFR-GTR
Car: 1993 s13
nice lines man looking good, tommy whats up man this is mark, dont know if you remember me, i met you at nopi, in mikes booth. ive got the rb26 s13 from va how you been man, is your shop still going
Carl H
i would use the proper thread fitting but thats me...otherwise not a bad idea.this is how i did mine...i have seen a few ka-t guys use brake lines for water lines, cheap and effective.i think my lines were about 30$ all in all to get done from the local hydro shop.
dizzywithsunstroke
Car: 1995 Nissan 240sx w/ RB20DET and 1997 Nissan Hardbody
carl, what mani is that?
Carl H
old school hks cast manifold, low mount and only works with the r32/33 xmember
mattleegee
Car: s13+19 corolla
Anyone know the size for the coolant sensor that goes to the gauge cluster? Im installing a WaterTemp gauge and it came with 1/8" threads, it came with some adaptors but all WAY to bigI was thinking m10 or m12? Autometer sells the 1/8 to 10mm or 12mm adaptors so i was going to just order one upOr is it better to hook the sensor into the coolant drain place on the side of the motor?
Got all my gauges wired in, just need this guy to work!
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
@MattI just used a bushing (M12? to 1/8 pipe - will verify) and tapped my manifold. Both original Nissan and Defi senders are next to each other.
I'm not a fan of the 'inline' style, purely due to aesthetics, but some people swear by them. To each eis own.
gawdzilla
Car: none
doesnt the gt35r have an m14x1.5 coolant threading? are you cross threading that brake line in there or is it the proper thread?
sepulchralx
Car: 240sx
gawdzilla wrote:doesnt the gt35r have an m14x1.5 coolant threading? are you cross threading that brake line in there or is it the proper thread?
Yeah it does... no i was able to hand thread the fitting 80% of the way in. the rest of the way was with a wrench till the seat of the fitting was flush with the chra surface.. Same for the rb25 block. I took the fittings out the other day and they threads looked fine on both the fitting and the old banjo still t hreaded in fine as well. I was pretty surprised that the npt matched the metric so closely.
gawdzilla
Car: none
scary.... but whatever works i guess!
btw, i'm gonna be driving through richmond today on my way down to VIR. probably gonna pass through around 2-3pm
Carl H
wait are you cramming the flare fitting into the chra with the nut?if so then toss that idea out the window as its proly just bottoming out against the chra and will result in no coolant flow.you need to use the proper flare fitting adaptor to make it work...a hydro shop should be able to get the parts you need.
sepulchralx
Car: 240sx
Carl: they're not bottoming out, the lines were full of coolant and i measured the depth of the hole with the thread height on the flare fitting, shoudl be fine..
Gawdzilla: you should come to the dyno tonight, i'm having my car tuned.. really excited!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
So if you're just using a flare fitting, what is keeping the coolant from leaking past the flare? I'm with CarlH on how that flare is meeting resistance...it is likely bottoming out on something otherwise it would never get tight on the tubing.
To do it right, you should have used a metric to flare adapter fitting and a inverted flare tube nut to screw into the back of it.
