Nearly Constant Squeaking Noise from Driver's side Wheel
MattB
Car: 2001 Infiniti I30A
My G20 has a highly irritating squeak coming from the driver's side wheel. It happens at all speeds and sounds like metal on metal like worn brakes. But the brakes were checked as fine. The noise goes away when the wheels are turned to the right, and the noise itself is intermittant. What could cause this? It's amazingly annoying.
qship96
Car: 1996 Infiniti Q45
have you checked the c.v. joints?
MattB
The CV axle on that side was just resealed and regreased by the dealer so it should be good.
qship96
the "just" part of your comment concerns me! if it was recently done at dealer,take it back for them to diagnose,they should be able to tell you if it is related.if the boot was torn for some time before resealing,the dirt injestion usually destroys the joint,and it should be replaced,not just relubed and resealed.
MattB
Interesting. It had been squeaking for a while prior to this work being done, and the CV axle on the other side was replaced when I bought the car. I'm definately going to have it looked at.
