maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Mon Oct 06, 2008 8:34 am
Gregg, I finally remembered to talk to my buddy about that motor. It's an S14 motor, I don't know the miles cause he pulled it from an S13 coupe he used to have. It ran good, but smoked after he added a 2:48 intake cam so he's going to give the original cam with it. I never saw it smoke, when I saw it, it was before the cam so I do know that it was fine before that. There's no starter or flywheel, but other than that all accessories are there (not sure about ac compressor, I doubt it). Last compression test he did was 160's across the board.
He's asking $350, but 'cash talks'. The reason its that low is because he can't guarantee the smoking will go away after you put the cam back in, but it should. Just give him a call, his name is Wes, and his number is 678-478-8488
