Don't go to your dealer with questions Just come here first or go right to the technician. You can get the module for DRL. That's what people do here in Canada if they bring the car in from the States. They have to go thru inspection.
Check this out. Same module probably work for you too.
http://www.hamsar.com/Content/...onics
2. Open battery box cover and also open wiring cover attached to battery box on the right fender side.3. Hamsar 45020 Black wire: ground to the body or Battery(-)4. Hamsar 45020 Red wire: Battery (+)5. Hamsar 45020 White wire: connect to fog light wire(white color) coming from the fog lamp(There are several white color wire, be careful)6. Hamsar 45020 Green wire: connect to oil pressure switch wire(orange color with silver stripe) at the bottom of engine right front near oil filter(45020 orange wire: not used).It works great.DRL turns on only when the engine is running.Original light switch functions are not affected.
It is installed on the FX but it should be same or similar.
