Navigation issue
Forum for the unique Murano, and official home of Nissan Murano Club!
pmatawan
Car: 2020 Nissan Murano Platinum
I have a 2020 Murano Platinum. The navigation system drops the house number and announces arrival when you reach the final street. I'm entering address manually, not through voice recognition. Doesn't happen every time, but often enough to make it useless without a smartphone to get you the last mile. Anyone else have this issue & is there a fix?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Try hooking up the WiFi and reloading the latest map data for your area, sometimes the maps get corrupted and it can cause all sorts of weird issues.
pmatawan
Loaded new map version and still having same issue.
Here is what I discovered:
If I enter the City first, it drops the house number, even after house # and street have been manually entered.
If I enter the house number & street before the City, it works as it is supposed to.
Is it only supposed to work one way?
VStar650CL
Technical Expert
Yep, that's normal. Dunno why they programmed it that way, but a few of the other models also seem to do that.
pmatawan
Thanks for confirming that that the Nav is poorly programmed and not malfunctioning.
Had a 2009 Murano, never had an issue.
VStar650CL
Technical Expert
Your '09 most likely had a Panasonic or Clarion, your '20 has a Bosch. I could bend your ear for an hour about how unhappy we all are with Bosch radios and navis.
Return to “Murano Forum”
