The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Fri Aug 07, 2009 5:47 am
jankenpo30, since I haven't said it yet, thank you for the many detailed responses you have provided.
I think I am reading the schematic correctly. However, I am certainly confused by how you are saying the DPDT switch and Parking Brake signal work.
Also, I am not confused about a previous poster with the brake light on, and haven't been, I'm not even concerned about that because I know other users have the hack working. Also, I think that is from a totally different thread, if not a different forum (though I have seen it).
I totally understand how to do only NAV, I believe I understand how the instructions say to do both.
Another way to rework my initial question (assuming I actually understand the schematic) would be these two questions:1) "If I install the hack for the DVD functionality (hacking both wires, per provided directions), would there ever be a scenario where I needed to flip the switch away from the hacked position due to altered/degraded functionality of anything in the M other than the NAV?"2) "If I was stupid enough to drive around with the parking brake on in an unhacked M, would the NAV work properly?"
Those aren't by any means the question I asked (or intended to ask), but their combined answers should tell me what I believe I want to know.
All of that said, I will go on (even though perhaps I shouldn't seeing as how we are really dirtying up this thread). Regarding my understanding of DPDT switches (from some electronics classes several years ago, wikipedia, and my interpretation of the schematic above (and a discussion I read in a thread regarding someone using the wrong the wrong type [on-off-on instead of on-on] of DPDT switch [more accurately, a DPCO switch instead of a DPDT switch]), the schematic and instructions call for a switch that offers these two unique positions:
(drawn in ASCII, legend follows)
Position 1 (normal operation):
B-~-A-o-CoooooooooE-~-D-o-F
Position 2 (hacked operation):
B-o-A-~-CoooooooooE-o-D-~-F
Legend:A = NAV/VSS signal wire to NAV plug/pinB = NAV/VSS signal wire from vehicleC = Open pin on switch DPDT switchD = Parking Brake signal wire to NAV plug/pinE = Parking Brake signal wire from vehicleF = Vehicle Ground- = internal switch patho = open/no connection~ = connection created by switch position
If this were accurate, 2 SPDT switches would not be a PITA; the A-B-C switch would hack NAV, and the D-E-F switch would hack DVD (but only when the ABC switch were also in the hacked position based on an earlier post by you indicating that both signal hacks are necessary for DVD). Moreover, a SPST switch and a SPDT switch would work, as A-o-C is the same as the OFF position of a SPST switch. My thoughts with a single SPST switch only inolved leaving E permanently disconnected and D permanently connected to F with no switch. At this point, the parking brake signal would always be hacked, and potentially allow full hack functionality whenever the NAV/VSS signal was hacked. However, your description of the functionality of the switch causes me to visualize something more complicated that sounds more like a relay that I honestly can't come up with a clean way to draw and I am not 100% certain I fully comprehend. That said, I am curious, have you actually checked the signals at the NAV unit plug/pins (accessible while the NAV unit is functional via the appropriate soldered points on the DPDT switch) in the hacked and unhacked positions? I would assume this would require a multimeter (volt and ohm tests would be necessary) and a driver (while you sit in the passenger seat) in order to fully verify what is happening there.
