Austin, you forgot about the wing, so add like atleast $200 more.ChampaignSilviaS14 wrote:Front bumpers range from 350-600 dollars usually, sideskirts usually go for around 2-300, and the rear valences can be found around 100-200 dollars.
Check ebay a lot.
If someone is looking for subtle OEM styling, I would not recommend something as agressive as a Blister kit.KC240SR wrote:And, if you can even find a set of original pieces, you should be prepared to pay with atleast one of your testicles (probably both), this is why you should just get a blister kit.
The 180sx Type-X spoiler is on anything but the 180/hatch 240's FYI... Please don't do it...Nytovaok wrote:thank you gentlemen. i fell in love with the zenki even more now. i was considering a navan kit, but i like the stock se foglights better, so i may only do sideskirts and valences. i also like the 180sx type x rear wing better. thanks so much for the input.
