Four NAV parts are typically required for the conversion:
(1) Touch Screen Display (2) Control Panel for Display (3) Faceplate / Climate Panel (4) NAV Unit / Radio Receiver
Cars with an '07-09 NAV System only require parts 1 and 4.
Cars with a BOSE Audio System (non-nav) require all four nav parts.
Cars with a Base Audio System require all four nav parts and need to: (5) Add an amplifier to power the car speakers.
Base Audio System cars with no factory rear camera should also: (6) Install a microphone, for voice communication.
PARTS FOR THE CONVERSION
From a 2010-2015 G37, Q40, Q60, EX35, EX37, or QX50 with Nav.
Part No: 28091-1BY3A, 28091-1BY3B, 28091-1BY1E, 28091-1BY1F, or 28091-1BY3C.
(2) Control Panel for Display (not needed for 07-09 NAV cars)
From a 2008-2015 G37, Q40, Q60, EX35, EX37, or QX50 with Nav.
Part No: 28395-1UF1A, 28395-1UF2A, 28395-JK605, 28395-JK65B, or 28395-JK66B.
(3) Faceplate / Climate Panel (optional for 07-09 NAV cars, the existing faceplate can be reused)
From a 2010-2015 G37, Q40, or Q60 with Nav. Part No: 25391-1UF3A.
or
From a 2008-2009 G37 with NAV. (These faceplates have a hard drive slot on them).
Part No: 25391-JK64B or 25391-JK65B
Part No: 25915-1JA0B, 25915-1JA1E, 25915-1JA2B, 25915-3LZ1A, or 25915-3LZ1C
(Note – these nav units don't natively support RCA inputs; USB input only).
or
From a 2010 FX35, FX50, or EX35 with Nav.
Part No: 25915-ZX74A or 25915-JJ52C
(Note – these nav units support both RCA + USB inputs, however they may require dealer reprogramming to activate the rear camera, since those vehicles have around-view monitoring).
(5) 4+ Channel Amplifier - BASE Audio System Cars Only
The 2010+ NAV Unit/Radio does not have a built-in amp like the Base audio radio unit, so an external amp needs to be installed to power the car speakers.
(6) Microphone, for voice - Base Audio System Cars with no factory rear camera
These cars don't have microphone, and so should install one. From a 2008-2015 G37, Q40, or Q60. Part No: 28336-JK60A, 28336-1VZ0A, or 28336-1VZ0B.
---------------- END OF PARTS LIST ----------------
With the correct parts all you need is to either purchase a Harness Adapter Kit such as: https://www.ebay.com/itm/333982567715
https://www.ebay.com/itm/333958203751
Or Get a Factory Harness From a 2010-15 NAV Vehicle, and then pin-out, cut, & splice the connectors to your existing harness, using the FSM wiring diagrams as a reference. In some cases, additional wiring (like for the microphone) would also need to be fabricated.
And that's all there is to it.
Hope that helps.
