(1) Touch Screen Display (2) Control Panel for Display (3) Faceplate / Climate Panel (4) NAV Unit / Radio Receiver
PARTS FOR THE CONVERSION
From a 2010-17 FX35, FX37, FX50, QX70, M37, M56, QX56, QX60 or QX80 with Nav.
Part No: 28091-1JA0B, 28091-1JA0D, 28091-1JA0E, 28091-1JA3A, or 28091-1JA3C.
(2) Control Panel for Display (not needed for ‘09 NAV vehicles looking to upgrade)
From a 2009-17 FX35, FX37, FX50, or QX70 with Nav.
Part No: 28395-1CA2A, 28395-1CA2D, or 28395-1CA4D.
(3) Faceplate / Climate Panel (optional for ’09 NAV vehicles, the existing faceplate can be reused)
From a 2010-17 FX35, FX37, FX50, or QX70 with Nav.
Part No: 25391-1BU6A.
or
From a 2009 FX35 or FX50 with Nav. (These faceplates have a hard drive slot on them)
Part No: 5025391-1CA5A or 5025391-1CA5B
(4.a) NAV Unit / Radio Receiver: To convert 2009 - 2017 NON-Nav vehicles
From a 2010-15 G37, Q40, or Q60.
Part No: 25915-1JA0B, 25915-1JA1E, 25915-1JA2B, 25915-3LZ1A, or 25915-3LZ1C
(Note – these nav units don’t natively support RCA inputs; USB input only).
or
The nav units below can also be used, however they may require dealer reprogramming to activate the rear camera, since the 2009+ NAV vehicles have around-view monitoring.
(4.b) NAV Unit / Radio Receiver: To convert 2009 NAV vehicles
From a 2011-17 FX35, FX37, FX50 or QX70.
Part No: 25915-9GE1A, 25915-9GE1B, 25915-9GE1C, 25915-9GE1D, 25915-9GE2A, 259153WY0C, 25915-3WY0D, 259153WY0E, or 25915-3WY2B.
(Note – these nav units don’t typically support RCA inputs; USB input only).
or
From a 2010 FX35, FX50, or EX35.
Part No: 25915-ZX74A or 25915-JJ52C
(Note – these nav units support both RCA + USB inputs).
---------------- END OF PARTS LIST ----------------
With the correct parts all you need is to either purchase a Harness Adapter Kit such as this one: https://www.ebay.com/itm/334124253577
Or Get a Factory Harness From a 2010-17 NAV Vehicle, and then pin-out, cut, & splice the connectors to your existing harness, using the FSM wiring diagrams as a reference. In some cases, additional wiring (like for the microphone) would also need to be fabricated.
And that's all there is to it.
Hope that helps.
