nav update
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
jmy0ung
Car: 2009 G37 vert
I received an E-mail about the 2011 upgrade code. Does anyone know if it actually adds much to the existing data. I have the 2009 software installed in my unit now. I don't care about the cost...just is it a substantial upgrade.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Your going to have to call Navteq and ask what is new in the 8.4 map update. Also remember that this update has to be done at the dealership (if you own a convertible) as the nav software is on a hard drive.
bschurr
Car: 2009 G37S 6MT Conv
jmy0ung wrote:I received an E-mail about the 2011 upgrade code. Does anyone know if it actually adds much to the existing data. I have the 2009 software installed in my unit now. I don't care about the cost...just is it a substantial upgrade.
Yeah - I got that too. $149 plus a trip to the dealer for install. WTF?
jmy0ung
Car: 2009 G37 vert
Dealer wants $81 to install it.
jmy0ung
Car: 2009 G37 vert
Installed by dealer today. Looks like a waste of time and money. The bar across the bottom that shows temp or radio info is a bit smaller with smaller text. I don't see any improvements but I do live in a fully mapped area.
cmesurf
Car: Infinitis, 03 FX35, 07 g35 sedan, 05 FX45, 09 G-vert & 14 Q50S Hybrid AWD
Not worth the time and the cost... 2009 map/nav is fine for the amount of driving ...
joe603
Car: 2014 Durango R/T
It does take some time to upgrade...Infiniti did not design the system to be user friendly for updates.
They update new subdivisions/roads mostly...
http://www.navigation.com/is-bin/INTERS ... erica-Site
jmy0ung
Car: 2009 G37 vert
Ok just got back form a trip from VA down through the carolinas. Places that said something to the affect that this area is not completely mapped on my last trip are now mapped. I did not run into a single place that was not complete. So my mind has changed....to me the upgrade was worth it and I would do it again.
cmesurf
Not worth the time and the cost... 2009 map/nav is fine, the one upgrade code is really 2010 map, the 2011 will be released in Sept 2011.
cmesurf
Not worth the time and the cost... 2009 map/nav is fine, the 2011 map up dates s/b 8.4 or 8.5
Fezzik
When you did the update, did it still go straight to the nav screen after startup? What I am making sure is that there is no OK button to push after you start the car.
DudeZ
Car: 2009 Nissan 370Z
gone - 2008 Nissan a/c
Fezzik wrote:When you did the update, did it still go straight to the nav screen after startup? What I am making sure is that there is no OK button to push after you start the car.
navigation updates do not change any of the functionality of the system... they only update the actual map (streets, road names, construction).
so, if your system requires you to press "OK" before seeing the map, installing this update won't change that. it will still show the "OK" screen and always will.
jmy0ung
Car: 2009 G37 vert
My car has always gone straight to the screen It was on when I turned it off. No OK button unless you were last using the nav screen. Then while driving if I change to the nav or map screen I get the OK button. I have the KP tech nav over ride installed but that only deals with the OK push if you start with the nav or map screen. The KP tech module is great for entering data in grayed out areas when you are on the move. I also have the KP one push top open module that I use all the time.
Return to “G37 Convertible Forum”
