You have factory nav in your Pathy?REZN wrote:well the navigation system comes with the climate control installed so idk how that would work and umm yeah worst idea.i hate minesits there because i dont have the money to replace it with a pioneer or something
Qxx4- I have a aftermarket In dash but my steering wheel button don't work. I really miss those buttons. Btw its alpine iva-w505 and is that a adapter you have to buy or special wiring to make it workQxxx4 wrote:did u mean you wanted to go with the factory nav system? i dont think thats worth it, very expensive and not as feature packed as an aftermarket nav. The good thing about it is that it had climate controls onscreen.
Pretty much all of us on here with aftermarket nav love it. Pioneer seems to be the way to go, they seem to be leading the pack, at least in popularity. They do require a gps antenna which is easy, i mounted mine near the defrost grille under the dash, you can actually reach down there from the front console area. The only problem is your '03 has an awkward shape around the stereo so prepare to make a trim piece. Im pretty sure your stock deck has that awkward shape as well but there are guys on here with aftermarket nav double din setups with 01-03 q's....so im pretty sure the factory brackets work fine.
OH dont forget to hook up a steering control setup too to make full use of that.
