NAV sys. conversion
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
mahin
Car: 2004 G35
looking for some information on converting NAV system in to a DVD player.
I am looking to have a shop do the conversion and how much did it cost?
smockers83
Car: 2006 G35 Coupe
Well, this could get a little tricky. DVD players are going to run about $500. The tricky part is hooking it up the A/V feeds. The stock head unit doesn't have stereo RCA inputs and I'm pretty positive the screen doesn't have composite RCA inputs. I'm not sure if they make RCA to pin-type connectors, but you'd have to find one that works with Infiniti. If not, you're looking at a complete overhaul--DVD player, head unit, screen. If that's the case, I've given some help in this area. What I would recommend doing is buying a new head unit capable of playing DVDs and buy a new screen. You put the new screen where the old one is and hook it up to the head unit. That way you can still watch movies up front while the vehicle is in motion--just don't let the 5-0 catch you.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
No need to do the above.
What he needs is the double din mounting kit for the G35. It is a Jdm part although I think there are now clones available. It replaces the stock radio trim - and I believe with some kits u lose the dual climate control (i never use mine). You will be able to add a double (or single) DVD screen/ player in place of the stock radio AND keep the factory pop up nav.
http://cgi.ebay.com/ebaymotors...70418
smockers83
Car: 2006 G35 Coupe
Cali 2 Balti G wrote:No need to do the above.
My recommendation takes yours a step further... With mine you can have a nav screen and a movie at the same time up front.
smockers83 wrote:What I would recommend doing is buying a new head unit capable of playing DVDs and buy a new screen. You put the new screen where the old one is and hook it up to the head unit. That way you can still watch movies up front while the vehicle is in motion--just don't let the 5-0 catch you.
Doing it those ways is the easiest way and will cost about the same. However, the JDM kits, if they're even being manufactured still, aren't available in the US at the moment for whatever reason. That Turbo kit, I would recommend staying away from. The quality isn't that great...the buttons are rubber for starters.
Return to “G35 and G37 Interior, Exterior and Audio”
