Nav Hack - Done
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
I think I made a post in a previous thread that a monkey could do the hack in 30 minutes....lol Maybe if he just twisted the wires together. I hate soldering wires! I now remember why I don't do electrical work or stereo installs anymore
Don't ask me how long it took
palincal
Car: 2007 M35 Sport
Does your navi stop tracking when you switch to DVD mode?
ken in az
1989 Nissan 300ZX
palincal wrote:Does your navi stop tracking when you switch to DVD mode?
No, it still works actually. I thought it wouldn't, but it does.
I have the 7.4 Nav dvd if that makes a difference.
M45Runner
Car: 2006 Infiniti M45 Umbria Gray
ken in az wrote:Don't ask me how long it took
So, how would you rate the difficulty of this job? Oil change as a 2 (Air filter change as 1 I suppose) and Replace engine / transmission as a 10.
Also, when did you started the job and when did you finished?
ken in az
1989 Nissan 300ZX
Actually it can be super easy or really difficult depending on how stealthy you want to be.
I went with a level 4 stealth factor from the late 80's and would rate it at a 2.9
jetfxr1
Car: 2006 Infiniti M35X Premium Package
Can you help a brother out in doing the NAV bypass. I've read the G35 Tech Page on it and a guy sells the instructions for $40 on EBay. Is it the same set up as the G35 Nav bypass?Thanks for any help you can give.
ken in az
1989 Nissan 300ZX
jetfxr1 wrote:Can you help a brother out in doing the NAV bypass. I've read the G35 Tech Page on it and a guy sells the instructions for $40 on EBay. Is it the same set up as the G35 Nav bypass?Thanks for any help you can give.
If you have an M35 why not search the M section for the nav hack?
jcarpent16
Car: 2006 Infiniti M35 Sport
General question: will the nav hack void an extended warranty?
ken in az
1989 Nissan 300ZX
jcarpent16 wrote:I'm lazy and don't want to try and think for myself question: will the nav hack void an extended warranty?
Yes - don't do it, it will also make you go blind
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
Look here: zer...ness
jetfxr1
Thanks for the link. It doesn't look that hard. Just need a good place for the switch on a Prem Package setup. I'll get started this afternoon.
jcarpent16
Apprecitate the help, buddy. With the amount of time spent nerding up my post you could have said yes/no. Nevertheless, I searched and found. voila. Still skeptical though. Hard to believe you can bypass some factory setting, have your Nav screen crap out, and Infiniti replace it under warranty.
ken in az
1989 Nissan 300ZX
jcarpent16 wrote:Apprecitate the help, buddy. With the amount of time spent nerding up my post you could have said yes/no. Nevertheless, I searched and found. voila. Still skeptical though. Hard to believe you can bypass some factory setting, have your Nav screen crap out, and Infiniti replace it under warranty.
No problem, give a man a fish and he'll eat for a day - get used to it with car forums.
Oh, and If you wanted a direct yes or no answer from some "guy" on the internet about warranty then I feel sorry for you "buddy" because a warranty claim is not a simple yes or no answer.
Think positive and positive things will happen. - the positive in this situation is that you learned to search and think for yourself, good job! Or you could be mad at me - either way you still figured it out right?
jetfxr1
Don't let Ken in AZ bug you, he's not that helpful to anybody. This forum is for people to help and discuss issues with others, not give a smart a** remarks to everyones posts. Now on to the NAV Hack. I just completed the mod last night and it works as advertised. I didn't use the CAT 5 cable or solder that mod suggests because it's simple wiring. I used 20 gauge wire with raychem splices at the harness and quick disconnects at the switch. I got some DPDT (double pole/double throw) ON/ON Rocker switches off EBay. They look like most of the switches in the car, and I plan to mount it in the glove box next to the NAV Reader. There is space, front and rear to install it. I have a Prem. M35X so I dont have the wallet holder area to mount the toggle. I'm currently using a ON/OFF/ON temp. switch until the EBAy one shows up. It works just the same, if you can't find a ON/ON switch.These are the mod. variations that I found that work. I hope this post HELPS everyone that reads it, that is MY intention on this site.
ken in az
1989 Nissan 300ZX
jetfxr1 wrote:Don't let Ken in AZ bug you, he's not that helpful to anybody. This forum is for people to help and discuss issues with others, not give a smart a** remarks to everyones posts. Now on to the NAV Hack. I just completed the mod last night and it works as advertised. I didn't use the CAT 5 cable or solder that mod suggests because it's simple wiring. I used 20 gauge wire with raychem splices at the harness and quick disconnects at the switch. I got some DPDT (double pole/double throw) ON/ON Rocker switches off EBay. They look like most of the switches in the car, and I plan to mount it in the glove box next to the NAV Reader. There is space, front and rear to install it. I have a Prem. M35X so I dont have the wallet holder area to mount the toggle. I'm currently using a ON/OFF/ON temp. switch until the EBAy one shows up. It works just the same, if you can't find a ON/ON switch.These are the mod. variations that I found that work. I hope this post HELPS everyone that reads it, that is MY intention on this site.
lol - I'm not that helpful? How about you take your 7 posts and spend a little time reading some of mine. I've probably helped more people on this forum than posts you've read
antzrus
Rosewood/XM/Tint/
Hey you guys, let's face it, the truth. I'm probably the most helpful, brave, clean, cheerful, thrifty and reverent of all on this list. My wife says so and she's smarter than me..!
ddynasty1120
Did you do anything different that your navi tracking still works? You just followed the directions step by step for it!
fiveliterbeater
Car: 2006 Mitsubishi Lancer Evolution IX
2000 Nissan Maxima SE
2005 Nissan Altima SE 3.5
hes not the only one that would have given this guy the same answer; Ken just happened to beat me to it.....
07sportm35
Car: 2007 Infiniti M35 Sport
Hey fiveliterbeater how are you? How's the spacers working out for you bud?
To KENAZ, we will be doing a photo shoot today in downtown Phoenix. If there is anyway possible please try an show up. E-mail me for the details.
I'd love a few M's there to represent.
jetfxr1
The Nav system takes about 10 seconds to update after switching back to "normal" mode. I also noticed that I had to be moving for it to "find itself", when I was sitting idle it would not relocate.
fiveliterbeater
07sportm35 wrote:Hey fiveliterbeater how are you? How's the spacers working out for you bud? .
doing good bud. spacers are working out ok so far. i was going to post pics but my car is in the body shop. i'll be posting pics as soon as it gets out. i'm still debating wether to keep 20mm in the rear or buy a 15mm for the rear.
ken in az
1989 Nissan 300ZX
Awe man, I would have loved to come down. Too bad I was in bed all day recovering from last night. Went to Durants for dinner and hit the tempe improv for a good friends b-day and I can say I was hurtin.
I'll send you an email with my contact info because I am down anytime for cool stuff like that. If I have a day or so warning I can usually make it. Thanks for the invite.
ken in az
1989 Nissan 300ZX
ddynasty1120 wrote:Did you do anything different that your navi tracking still works? You just followed the directions step by step for it!
Yup, I just followed the directions to a "T" if you will. I still have my old nav dvd so maybe I'll try and pop it in and see if that makes a difference. I'll report back tomorrow when I drive into work.
07sportm35
Cool Ken.
Took a few pics...
ken in az
1989 Nissan 300ZX
Lookin good - where abouts were you guys? Looks like you were up on central northish, am I right?
07sportm35
ken in az wrote:Lookin good - where abouts were you guys? Looks like you were up on central northish, am I right?
Yep. Central and Thomas area. It would have been nice to have you there.
ken in az
1989 Nissan 300ZX
Wierd NAV stuff this morning...
Get in the car and drive about 10 miles - NAV is working perfectly. I forgot the old Nav dvd to try it out so I figured that I'd hit the switch to watch a dvd. Well it was already flipped in the dvd watching mode.
So I then flipped it back to the "stock" setting and it continued to work. Then but maybe 30seconds later I flipped back to dvd mode and it quit working. I was dumbfounded because it had been working all morning till then.
I then flipped it back to stock while driving and it found itself in less than 10seconds. I flipped it off again and waited about 5 miles to see it it would start working again but it never did, it knew what direction it was pointing though. I left it that way till exiting the freeway and came to a stop at the light, withing 5 seconds it found itself without me having to switch it back to stock, but once I started moving again it stopped tracking again till I flipped the switch back to stock.
So, I guess it works when it wants to, and other times it doesn't. Probably a whole list of things that Nav system is doing to figure out where it is.
