RC wrote:just a goal of mine I'd like to achieve. i'd get really good props and I've always been taught the less moving parts in an engine, the more reliable it is (obvious). I'm sure I'll turbo my next project though just for the hands-on knowledge. as for that megasquirt system, that sounds perfect for me because I'm always wanting to learn more about everything on a car. budget is somewhat of an issue but I've been having good luck on hookups so hopefully i'll luck out some more. Thanks!
Im am not too sure of the NA option keeping up with an average SR on pure speed and acceleration. there are so many advantages to the SR over the stock KA, but I do think if you are going to try top build a competative car, you could start with the handling and drivetrain first. Lightweight flywheel, clutch, rear end, maybe some coil overs for your specific type of racing. bushings, brakes. Adding those parts wont make you faster power wise, but with a good suspension tune you will be able to keep up with most of them on an autox track. most SR owners I come across get coilover, but fail miserably on tuning a suspension for their preferred type of racing. Adding camber plates and drift coilovers actually doesnt help you straightline acceleration because most of their spring ratios are stiffer and more tire angle decreases contact the contact patch.
If you are trying to learn more about the car I also recommend keeping the motor stock while you are learning. that will elliminate outside factors. Only go for exhaust and intake upgrades to start.
You have to be specific with what you do and make all your changes meaningful. You do this and it will balance out your chances. Expecially when you start adding power. And I apologize for the other junk that was going on within this thread. Good luck on your build
Use the Nico sponsors to find things, some of them offer discounts to members.
