mopower »
https://forums.nicoclub.com/mopower-u37304.html
Sun Aug 05, 2007 3:17 pm
Hey Nico Techs,
I'm hearing this nasty noise coming from the underside of my manual 93 240sx coupe.It sounds like a croak croak sound when you're inside the car, but hearing from the outside, it sounds more of an 'khouk, khouk' like something's grinding or scratching..When I let the car roll and going down a drive way, that noise appears at that certain angle as well. At speeds higher than 15mph, you don't hear it.Also, when rolling, AFTER braking semi-hard, the noise will appear again.
I thought they were my springs/shocks, so I replace those, but still there.Then I thought it was something to do with power steering, so I added more fluid, noise still there.
Then I noticed something really strange, the noise only comes out when the car is warmed up and driven for about 5 mins. The noise is not there during cold weather.
Is there a component under the car that when heats up, it makes this nasty noise?
T.I.A.
