nasty clunk from the rear, please help
neverlift
I have looked over the rear end a bit and found nothing relating to what is making this noise, it sounds almost like a loose wheel, but the lugs are tight.
Any input would be great, suspension is basic coilovers,rucas,welded diff,stock sway/bushings all around...
TY!
captainfalco
Car: S14,MX83
I would guess either subframe bushings or differential bushings.
neverlift
any way to visually tell?
this happen during a spin, car spun it felt different than normal spins and then I went to turn right and you can feel the wheel like its hoping out of alignment. are these signs of diff/subframe bushings being bad? I am desperate lol, I have another ride, but I would like this to get fixed today or tomorrow.
neverlift
ok I just put it on stands and the rear right(where I feel the issue) wheel has some play, I assume that would be the wheel bearing is bad? if anyone knows for sure this is it lmk please and thank you!
