MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Fri Sep 20, 2002 5:57 pm
Automatic... yes but:
Chassis: 1998 240sx LE / Pearl White with factory sunroof Engine: KA24DET Custom Built Stage III by Top End Performance, No. Hollywood, CA Micropolished and knife balanced crankshaft, JE Forged Pistons with Total Seal rings,Race Prepped Rods (shot peened, mangnifluxed,) Ported and polished Head, Block bored .040 over, Turbonetics T3/T4E 57 Stage V 63 ar Plain Bearing Turbo, HKS Manual wastegate, HKS Racing blowoff valve, Spearco Intercooler, 50 lb msd injectors, Jim Wolf Technologies fuel rail, Jim Wolf Technologies custom programmed ECU, Ford Mustang cobra MAF, HKS 200CM air filter, All piping red powder coated, Fmax turbo exhaust manifold and downpipe custom high temp coatings, HKS EVEC IV electronic boost controller, APEXI GT All Stainless Exhaust system cat back. B&M External oil cooler with aeroquip hoses, Remote oil filer for secondary filtering, NGK 7C11 cold heat platinum spark plugs, Vortech SMFU Variable rate fuel pressure regulator, Manual fuel pressure gauge, DC Sports polished oil cap, Manual fan and schroud removed (electric fan in place), Custom 3 core high volume radiator, Morroso remote battery box and cabling (to rh side of trunk), Red Redline 10w40 oil Transmission: Automatic, Level Ten valvebody upgrade, Limited slip differential, External transmission oil cooler, Suspension: Tein HA coilover system with adjustable dampers, Tein front adjustable camber plates and pillows, Tein rear pillow mounts, Trust adjustable front strut tower bar, Cusco rear upper camber adjustable arms. Brakes: Nissan 300ZX Turbo brake conversion calipers and rotors,Porterfield R4S Compound pads, Stainless brake lines, Speed bleeders Wheels and Tires: Borbet Type M 17”X8” rims with carbon fiber inserts, Sumitomo HZR II 225r45ZR 17 Tires front, Sumitomo HZR II 255R40ZR 17 Tires rear 5mm spacers on the fronts Body Parts: Nissan factory side rails, Bomex Front spoiler bumper,Bomex Type 2 center grill, Bomex grill mesh kits, Bomex rear fender skirts, Trial adjustable rear spoiler, Nissan JDM S14 front turn signal lens assemblies, Nissan mid side turn signals, white lenses, amber bulbs, Re-badged Nissan Silvia logos and hood badge,Nissan K/S side badges, Custom hood lift struts, Catz fog lights Audio: Nissan CD/Cassette/FM/AM/d\Double din unit made by Bose with 6 speakers, Clifford IQ800 Alarm system with proximity sensor, Bell 855 radar detector, G-Tech performance meter Interior: Stock Nissan gray leather interior, Carbon fiber dash and wraparound kit, Levoc white shift lever with overdrive button,Autometer oil pressure gauge, Autometer fuel pressure gauge,Autometer boost gauge,Autometer fuel/air ratio meter,Autometer gauge pod, Four point seat belts and harness Graphics: Daytona flags by Stripeman graphics, Maufacturers Graphics by Aero decal, Zebart undercoated and maintained including paint protection.
Sorry..that was probably rude to post all of his mods here... but I mean... come on... 75% of them are performance oriented. That's pretty impressive.
