demcj wrote:you're not serious are you? i thought this was a big no no
. isn't this almost the same as running an aftermarket spring on stock shocks?
-demetrius
its worse. when you cut/heat spring and all that, you DO increase spring rate, but you'll never really know by how much. C-kwick, q45tech and a few others had a long discussion about it. all in all, cutting springs is just ignorant. YOu're stock springs werent designed to opperate without 2 coils(or howerever many you take off), nor were your shocks, and...since the springs arent really much stiffer, the travell will be the same in any given load(excepting the small increase in spring rate due to shortening the spring) but will have less total travell area(from say 3" travel to 1.5"), which is a very bad thing.
Demetrious, if you dont need the height adjustment, get some S.techs and AGX's.
Dennis kalman liked his apexi(likes) WS, just dont drop them(or the teins) over 2", since you'll be compressing the damper too much, and it may fail. my vote is for the apex-i peices, they're 30% stiffer than stock, and are nice quality.
TEIN makes a good one also, so it may just boil down to whats cheaper....-chet
