Big Red »
https://forums.nicoclub.com/big-red-u2123.html
Fri Feb 13, 2004 6:01 pm
The stock steering wheel uses contact slip rings as well, I think you need to take more stuff off.
Did you use a steering wheel puller tool?
You can rent one, the part number is: ST27180001 or J25726-A
Use a multi purpose grease on the turn signal cancel pins and contact rings when putting the new ring on.
