xekushnr »
https://forums.nicoclub.com/xekushnr-u16901.html
Mon Jan 15, 2007 5:10 pm
if you are sure you have fuel and spark then check for compression. if you havent had your MAFS hooked up, do that. make sure you swap in a buddies ECU and see if thats the problem.
also, the coolant temperature sensor is different than the thermostat. the thermostat meters the flow of coolant in the engine, while the CTS actually measures the temperature of the coolant. CTSs do sometimes cause no-start conditions IIRC.
