Name this wire!
mr_wizard
Ok I was connecting my motors wires back up and I came to this.... what the hell is it and where does it go!? I can't find the connection anywhere. Thanks all!
S13 240SX
Car: 93 Mazda Miata
hahaha dude thats a very good question.. i have no clue... i swap ka's and wiring and i have the same plug but I left it unplug and it seems to run fine without it plugged in.. no check engine light.. so I'm just thinking its something stupid and pointless because i dont know what the heck it is either.. but maybe we both will find out soon once other people post.. hehe : )
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Ground strap.
Take a look at firewall.
wild_maxx
Car: 90 TT pearl yellow z32
pregmantis
devious is right as usual. thats a ground strap, there should be the other half bolted to the firewall.
91RMKS13
Car: 1992 240sx
i am going to go ahead and name the wire pete. yes pete will be his name so it will no longer be named "this wire" it will be called pete.
say hi to pete for me .
All_Motor_KA
Car: 1989 240sx SE
Pete is a ground wire
mr_wizard
thanks guys!
S13 240SX
Car: 93 Mazda Miata
does it even need to be hooked up??? i just left mine go.. i have no problems.
91RMKS13
Car: 1992 240sx
it has a name remeber its pete and if you can find out were pete goes why not take him home.
pr240sx
Do yourself and Pete a favor and hook him securely to the firewall.Before he meets with Mr. Shaffing and Lady Heat
S13 240SX
Car: 93 Mazda Miata
pr240sx wrote:Do yourself and Pete a favor and hook him securely to the firewall.Before he meets with Mr. Shaffing and Lady Heat
hehehee. no seriously.. does it matter?? i have left that plug un-plugged for 7 months now i have no problems
SeanC
Car: 1993 240sx SE
why not just hook pete up? or another ground to replace him? or pair him with Elaine... but seriously why would nissan waste time and materials for something that doesn't do anything...
S13 240SX
Car: 93 Mazda Miata
seanc... why would nissan waste time.. because they do... nissan adds a lot of stupid parts on our cars that we don't even need.. like take for explain... upper timing chain guide... that was a pointless part all it does is break and when ya remove it the car still runs fine without it. that's just one explain.. i can name a few others that nissan didn't need to add.
and this whole ground wire plug it must be nothing big.. i mean what the hell is it gonna ground to...it's not like its going to the car battery or ecu because if it did then my car wouldn't run or start. i left it unplug for 7 months and my car starts fine and runs fine.
i'm just gonna leave the plug go because 1... so far i don't really need it i have no problems. and 2.. i can't even find it on the firewall where it gets plugged into.
91RMKS13
Car: 1992 240sx
yea your motor runs fine because it is grounded else where but it could still help i mean my friends honda has a few motor mounts it does not need them all but they are still connected because they seem to work better the more he has and could keep bad things from happening if one went out
pr240sx
Hook it up!, even install more grounding straps and distribute them around the engine.Try this, with a ohm-meter measure resistance thru several points of the engine.
Try to reduce resistance across the engine. you will have a smoother and more efficient engine!!
91RMKS13
Car: 1992 240sx
kind of what what i wanted to say ^
plus man pete needs a home
i hope you have nightmares of being homeless and think of pete and how he feels
mr_wizard
Sorry to say, but Pete died of Spontaneous Wire Combustion. Yes, tis true, he bursted into flames and was melt in half. RIP Pete.
91RMKS13
Car: 1992 240sx
well please promise me you will give him a proper funeral
pete deserves it
mr_wizard
What's left of him, yes I will
