name this wire
240DRFT
anyone know whats the wire for in the transmission harness thats the thickest one in the harness and its black and red and the ends look like you put them on something, there not plugs.
EDIT: i finaly got pics so scroll down to see them
Modified by 240DRFT at 10:50 AM 8/4/2005
tonynalli
pics?
All_Motor_KA
Car: 1989 240sx SE
Black with a red line? And is it a lil square type thing with a hole in it? If so it might be your starter power wire. Trace it back. If it goes to your battery then yeah it is. I don't know any other thick black/red wire on the harness.
240DRFT
All_Motor_KA wrote:Black with a red line? And is it a lil square type thing with a hole in it? If so it might be your starter power wire. Trace it back. If it goes to your battery then yeah it is. I don't know any other thick black/red wire on the harness.
i think you might be right...where does the main line from the positive terminal go then? this one is solid red.
i wish i could get pics.
All_Motor_KA
Car: 1989 240sx SE
It goes on the seloniod on the starter. The bottom bolt of the two. Should have a nut on it. It not get a nut and tighten it down.
240DRFT
so does the the main red wire from the battery go to the solenoid circle on the pic?? where does the black/red one go?
240DRFT
bump...allmotorka do u know? or anyone else?
All_Motor_KA
Car: 1989 240sx SE
There should be a wire that clips on to a clip on the starter. That's a ground. Then the wire that comes off the battery goes to the solinoid.
240DRFT
where on the pic is this clip? if its even there...
All_Motor_KA
Car: 1989 240sx SE
It's the only wire comming from the starter itself. The wire that is on the right of the two starters in the pic. Should be a clip hanging right next to it from your lower wireing harness.
240DRFT
i already have that plug, plugged in. that wire's not the big black/red one...the b/r is much thicker and has a ring on the end as if it would bolt on to something
All_Motor_KA
Car: 1989 240sx SE
Yeah that wire bolts on to the starter nut....
240DRFT
what nut though? thats what ive been trying to figure out...
240DRFT
allmotor do u have aim so i can talk to you for a sec so i can figure this out?
everybody else can add in on this too...
Modified by 240DRFT at 1:56 PM 8/3/2005
All_Motor_KA
Car: 1989 240sx SE
hehe. yeah. XxNozzleManxX. it's really easy man i think you're just a bit confused.
240DRFT
i should have pics by tomorrow morning...and i'll hit u up on aim tomorrow sometime allmotor, thanks
240DRFT
so heres the end of the b/r wire thats down by the starter area...its really thick and has that round end look: its the one in my hand...and its from the transmission harness
and heres the other end of it, i looks like it would go on a battery terminal??? im not sure:
240DRFT
