name this valve! (RB20)
apex_7
Car: 240sx
I've been having some crazy idle problems, mainly after the car warms up. My idle is usually around 1850+rpms! I just replaced the AAC, and what I thought was the IAC. I don't know what this valve is though!?! I've messed w/ the idle screw and tryed almost everything I can think of. I'm probably going to try bypassing this valve tomorrow. Does anyone know what it is?
Carl H
air reglulator.stupid high idle is proly due to improperly set tps not a valve.
Fenvy
Car: 2005 350Z Base 6MT
maybe idle air control valve stuck?
apex_7
Car: 240sx
nope, I took it off and soaked it in brake parts cleaner and it doesn't stick at all.
themadscientist
pirate air, arrrr! look for some hose off the intake that might have come off letting air past the throttle at idle.
apex_7
Car: 240sx
Carl H wrote:air reglulator.stupid high idle is proly due to improperly set tps not a valve.
not tps, checked that.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Something else you might want to check is your head temp sensor, those things can be fidgety and replacing one on my KA24 and my friends Z solved his idle problem. Try the MAF also just for the hell of it.
apex_7
Car: 240sx
Kansei240sx wrote:Something else you might want to check is your head temp sensor, those things can be fidgety and replacing one on my KA24 and my friends Z solved his idle problem. Try the MAF also just for the hell of it.
head temp sensor? where is that? I think the MAF is okay, but airflow maxes out (according to afc) in 3rd gear around 6800rpms, 12.5psi. I need to get a Z32 MAF anyway, but I want to fix this idle problem before I do anything else to the car.
thanks for your responces.
Kansei240sx
Its right by the water pump on by the radiator hose exit.
digzsublime
Car: 95 S14 w/ LS1.
Yeah that's right!! You betta work all of the kinks out of my motor Boyeee!!
