Name this part
bmart
Could anybody tell me what this is or if I need it? I took it off my rb20 front clip.Thank you
Cjmartz2k
Car: Hunting for a '89 GTR now
resistor for the fuel pump. direct wire with a relay and trash that
bmart
Alright, Thanks!
MATTs14
Car: Red 1995 Nissan 240sx
so you dont even need that part?
radianation
Car: 1996 Nissan 240sx with built RB25DET
I have that part sitting in box left over from an old RB20DET swap and never knew what it was for either. Thanks for this info.
Cjmartz2k
It is supposed to lower the voltage to the pump at low RPMs, and run full voltage at higher rpms, but I don't think it works right. I just used the factory wiring to switch a relay in the trunk powered straight from the battery. Went from 10.8 volts to 13.1 volts. I used big wires too, so now that I'm running two pumps, all I had to do was mount it basically.
