RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Tue Feb 02, 2010 7:30 am
That three wire plug looks like it could go to the o2 sensor or the power for the coils.
Most plugs on the harness only go in one spot but put those two next to each other and which ever one has more slack goes to the o2 sensor.
Are your spark plugs wet? pull your CAS and spin it and make sure all your injectors are firing, and same for your coil packs.
When I first swapped in my rb20 my injectors weren't getting power, the relay trigger was damaged and the relay by the ecu wasn't getting a signal.
If you do have spark fuel, do you have constant signal? My cas got damaged and was giving inconsistent signal at one point.
~Alex
