fanta »
https://forums.nicoclub.com/fanta-u16231.html
Fri Apr 29, 2005 1:31 pm
1. May be VSS, reverse. Rear plug on trans2. Alternator3. Oil Pressure4. Give me wire colors. May be many things, neutral switch on trans perhaps.5. Det.6. Appears to be the starter wire, shoule be one B/W wire.7. 8. Looks to be E203, connects to E18. Two wires, one W, one B. Connects to alt fuse in fusebox, other wire is the body ground.9. May be E204, has two wires, W and W/B. Plugs to E19.10. Can't tell at all.11.12. Colors13. Boost Pressure Solenoid14. Janky wiring job by previous owner. Inspect!
Get back to us on the wire colors, it's been a while since I unwrapped and shortened my harness. Absorb FSM sections "EF & EC" and especially "EL." Double-check what I posted, can't be sure without close-ups and/or wire colors. May as well unwrap it and take a good look at the wiring while you've got it laid out.
