Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Tue Jun 13, 2006 5:13 pm
Ok, so i went on vacation and got back sunday. i left last thursday so... the last time i drove was Wednesday, 6 days ago.
I turned the car on and jumped it and i heard a weird whirling noise... so i was like... Wtf.. i look under the car, and power steering fluid leak was there, ok.. its that leaking hose i need to replace, no big deal.
So it idles down and sounds normal, and then all of a sudden, i start hearing this abnormally louder than the injectors clicking.... Ok... wtf, as i would barely rev it , it was almost certain it was coming from the head, becuase it didnt have a deep sound to it at all, and was more high pitched like something in the valve train.
I just started up my car
My oil pressure was 55psiidle was around 900 ishoil was finePulled all the spark plugs, they're fine, just a bit black from running richand there wasnt an overabundance or really alot of oil in the crank case hoses.
Im going to take off my timing belt cover to see if it skipped a tooth, but wtf. It drove PERFECT before i left, and it didnt make the noise as soon as it started..... it only came after. Mind you this entire time of idling was about 5-6 minutes. I shut it off to be on the safe side...
Do you guys think it will go away if it warmed up more or.... should i investigate more into this?
::edit::
I took off the cam cover and CAS and...I checked the cam pulleys and they're lines up perfectly TDC with the crank pulley, so that rules out them slipping a tooth and the pistons hitting the valves.
Modified by Kansei240sx at 8:48 PM 6/13/2006
