DAEDALUS wrote:Silicone from the tension rod bushing?
NICO rocks. Daedalus, you're right on it. I crawled back under the car with my trusty service manual in hand (page FA-4) and sure enough, there was a drop of the mystery fluid right under the bushing.
I also noticed that the areas directly behind the bushing (transverse link assembly) is covered with this stuff. I guess the wind under the car blew it over the other parts.
I'm still wondering how it got inside the wheel well and on the driver door. That stuff must have initially squirted out of there.
Come to think of it, two days ago, the front suspension made a popping noise. Sounded like I had driven over a rock or something. Who knows, maybe I'm over-analyzing the issue.
I did a search for "tension rod" and found some articles where some suggest to just replace the entire tie rod since it comes with the bushing on it.
The question now is... is it a DIY job to replace and I guess I should go ahead and replace both the driver-side and passenger-die tie rods right?
Carlos
