Hey guys, so I know a couple of you may have seen my previous posts, and for my Z it's one thing to the next.
A quick synopsis although I doubt it matters for this issue: replaced spark plugs (PFR6b-11B gapped @ .035 per Greg at SZ due to 14PSI boost), replaced injectors (740CC), new SZ ECU, replaced valve cover gaskets, deleted EGR/AIV, deleted plenum water hoses, troubleshot a huge air leak that ended up being an o-ring in a bad place on an injector
So, after being down for 3 months and overcoming several hurdles, I finally got ALL SIX cylinders firing, and man was I stoked! Pulled her out of the neighborhood and noted to friend the lifter tick that was already there previously. Took her for about a 20 minute drive around, and the lifter tick sounded a bit louder than I remembered, but I hadn't driven her for 3 months, and I only had her for 3 months before that so I figured maybe it was in my head. By the end of the drive, it was becoming apparent it wasn't lifter tick, we pulled off, popped the hood and the engine had a terrible knocking noise at idle which definitely wasn't there before. It follows the RPMS as you will see below, and seems to be on the driver side and loudest at the exhaust valve cover via a mechanics scope. We left off and drove another mile or so, the noise was getting worse, sounding like I was dragging cans behind the car, and as I pulled up to a light the engine just cut out, didn't stumble and die, just cut. I've been having battery issues and haven't gotten a good charge on the battery due to not being able to run properly (I may also have a bad battery), but anyways, after 4-5 cranks it was obvious the battery was dying and we weren't starting. Pushed off, tried to get a jump. I've jumped it off probably 10-15 times due to running battery off and then while I was working on her due to not being able to charge it, and it always started really fast. Refused to jump and basically started to refuse to turn over much at all. Had her towed home. Finally tonight with the assistance of a battery charger I got the starter to run, but wasn't firing. I put the charger in starting mode, and the engine finally returned with the same noise. Enjoy a couple of videos below and shoot some opinions please!
[youtube]
http://www.youtube.com/watch?v=kT8gmlimxJg[/youtube]
[youtube]
http://www.youtube.com/watch?v=mfw2CW7vqIg[/youtube]
My friend helping me said he had heard that noise before on someone else's Z and it was rod knock. After doing some searching and watching youtube videos I've seen other people suggest things from oil problems to timing belt issues. I took part of the drivers timing belt cover off tonight and the belt right there was very tense and looking like it was in good condition. I will probably properly take it off tomorrow and get a better feel for the tension.
