jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Fri Dec 31, 2004 7:04 am
I've spent the last 10 months collecting parts and doing research before I start my swap. Im putting a rb20det into my s14 and have some nagging questions that I hope some of you can anwser. Is the tentioner an absolute must? Do I need to change the water pump and if so is the rb26 n1 the pump to go with or can I get away with a new stock pump. I dont plan on running over 300whp. The cluster my clip came with says it only has 40,xxx miles. So far I have a Walbro 255,two 10" pushers,rebuild gasket set,aem fpr,Greddy timing belt, and the r32 clip. I know I'll need guages, a downpipe, and maybe a clutch, all of which Im waiting on until the engine is out of the clip. What else are absolutely ecential before I start.
Thanks
