My Z hasn't been running very well lately. Symptoms are: bizarre and finicky idle conditions (cold start around 1500 sometimes even 2000 rpm, then when warmed up it usually settles to around 1000 when idling but ocasionally gets "stuck" at around 1500), low end power loss and slight hesitation, rough running in first gear (a little jerky, bogs down a bit), noticeable miss- when idling it vibrates and isnt as smooth as it should be. Misfire is only noticeable during idle and seems to have a "dead spot" at Around 2000rpms. When cruising at 2000rpms (not hard acceleration) it runs rough and kinda choppy. Any other rpms it runs smooth and fine, hard acceleration it runs fine. It still has lots of pull in the higher rpms, it just ssems to have a distinct bump at 2000. Another thing i should note is that the left exhaust tip has more carbon build up then the right, and when i pulled the plugs, the ones on cyl 4 and 6 were pretty black with build up, go figure. I just replaced the plugs before i did this, so plugs are fine: yes theyre ngks. Coils all ohmed alright and all seem to work. I checked the codes and got a 55, so all good there. Also checked the o2s, and they tested fine. I Cleaned injector connectors, reset the throttle body sensor, tried messing with the aicv a while ago but thats defs not gona fix much. I just did an oil change, new fuel filter, new air filter ( old one was disgusting and filled with crap). I thought that did someting at first but i guess not
Not really sure what to do now besides start replacing coils and injectors. Maybe a wiring harness. The car is still driveable but its annoying and a shame that the z isnt running like it should. Plus im getting terrible mileage, i put only 94 in it and im not made of money....
Any tips and suggestions would be appreciated, thanks!
