NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Sun Feb 08, 2015 1:33 pm
My clutch on the NA went out and I figured "while I'm in here, I might as well. . . and then it took off from there. Its not super expensive, to do it properly you would need to spend 5-6k if you do the work yourself, it really inst worth the hassle I just kind of jumped at the idea because I wanted to tinker and because at the time with a busted clutch I couldn't have gotten nearly enough for my NA to throw at a decent TT. The only major difference between the two is that the TT comes with HICAS (which most people do away with) and 3.69 gears IIRC, the NA gets 4.09s which is way more fun but also a bit more unforgiving from a dig or on wet roads. So in conclusion my advice would be, if you want to know your car inside and out, get angry with it, hate it, love it, want to kill it. . . Then do the swap yourself. Otherwise just buy a decent TT.
