NA / turbo heads
Fastbear
Car: Z32
HyMy turbo head are really badly damaged and they cant be rebuilt, i need to know can they be replaced with NA heads? Or what differents there are between them? Sry my bad english, im from other country..
Modified by Fastbear at 5:29 AM 8/12/2006
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I believe the heads are the same it's the cams that might differ, and any sdecetn machine shp should be able to rebuild your heads , anywhere from $100-$1000 depending on how bad they are
and welcome to NICO
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Actually if youll notice, the N/A and TT with M/T are the same, and TT/AUTO are different...
Interesting... Never would have guessed they would have put different cams on the TT auto only!
Fastbear
Car: Z32
well about rebuilding.. that hole(valve lifter guide?) were the hydraulic valve lifter goes in has gone to big(diameter).. so it moves side to side about 1mm even more maybe.. and that makes engine knoking like crazy, hydraulic valve lifter doesnt get oil anymore because that space. And yes rebuilding is possible put it cost more then the new engine..so its not acceptable... but thanks.. for the information..
