NA -> TT Conversion Guide
NolimitZ32
You will run into many unforseen problemas and even with the expertise Z1 has this motor/car comdination is a ***** and a Half to work on, 53 hours of labor is not much, changing the head gaskets on a VG30DETT (motor in car) by alldata is like a 30+ hour job by itself and those times come directly from nissan and the actual people that designed the car.
phanatikz32
Car: 1991 NA to TT z32 biatch!
wow i didnt know that the labor times were that much. even more reason to Frankenstein the car then. i mean most people are against doing rb series motors in a z and what not but it seems like the vg motor is such an *** to work on that even though the customization involved in swapping an rb or 2j into a z would be a biatch, the ease of working on it would make up for it.
Nissan300zx2+2
Car: 1990 Nissan 300zx 2+2 N/A 5 sp. manual for trade/sale, and A fully restored street/strip 71 Olds 442
Theres a shop in irving that will do a turbo swap, including both labor and price for the front clip for 5,000, pm me if you want more info
[quote="purple_ha"Z"e"]Is there any other place that will do the tt swap for me besides Z1? I would try to do the swap at home like you guys, but unfortunately, my friends are all into mustangs and cameros, so I won't be getting any help from them. [/quote]
WAM_Z32
Car: '93 Nissan Fairlady ZX
Nice as this is i guarntee someone will post within the next day on "How do i make my NA a TT??"
aka_jesus85
i got a 91 z32 n/a 5 speed and thinking of just going wit the stock turbo kit and ecu wit a bigger head gaskit for low compression and going to tune it so im runing 6-7 psi just so my car could be turbo. and would i be good??if no tell me y not??
GsaSlick
Car: 1994 N/A Slicktop 5-Speed
This is an awesome guide, hopefully I'll be using it in the future. Thanks!
300a7
Car: 1990 nissan 300zx
THANK U FOR THIS
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
What is the difference between the n/a motor and twin turbo, obv besides the turbos and all the turbo needs. Couldn't i just have my engine rebuilt (it has 124k on it) and get bigger turbos and better intercooler and all the other parts for cheaper and have a better setup then buying a twin turbo motor. Someone please let me know. thanks.
jedijeff123
Car: 1993 Ultra Red 300ZX N/A 2+2(SOLD), 1990 Aztec Red 300ZX Twin Turbo(Temporarily providing a home for a VH45DE)
DanDrath wrote:What is the difference between the n/a motor and twin turbo, obv besides the turbos and all the turbo needs. Couldn't i just have my engine rebuilt (it has 124k on it) and get bigger turbos and better intercooler and all the other parts for cheaper and have a better setup then buying a twin turbo motor. Someone please let me know. thanks.
from what i know the piston compression ratio is different, but that all that i can think of on a whim...
amandico26
Car: 300zx
hi where can i buy a fuel pump controller i have tt ecu and i just begin the swap on my z thanks
TAcroc
I dont see what the problem is on going na to tt. Sure there are some problems like the different radiator and such. But u can use the stock harness just as long as u have a boost controller. I have done engine swaps before on an na auto z31 and making it a turbo z31 with manual...along with an hx35w holset turbo, injectors, intercooler, nistune, wideband and all that regular stuff..but now Im looking for an na z32 manual right now and would be interested in the swap later down the road. Im moving out of the z31 group to the z32 :P just want more comforts and a a/c and radio that works haha.
dustovshio
Can the n/a 5 sp transmission be used in the swap? I read on this forum that the 5 sp is basically the same except you have to grind the started down to fit. Or could you just use an n/a started and n/a manual trans?
dustovshio
The head is different - the n/a has higher compression.
Re037
Car: 1992 300zx 2+2 NA
the mws directors cut vid links are down. anybody want to upload them???
