NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Mon Apr 18, 2011 8:43 am
Timing should be set based on logs, I couldn't really tell you exact because I haven't done the research but I would say you would have to be retarding it to ensure you were pre-detonating, your biggest problem with this setup will most likely not be timing but actually the wrist pins, on the NA they are super thin and tend to be the first thing to go under these conditions. Also I'd recommend if you are wanting to go this route, sell the AFC and get a Nistune as the AFC will not be able to make up enough fuel map expansion on top of the NA ECU for the car to run correctly.
