Jeff B »
https://forums.nicoclub.com/jeff-b-u171062.html
Tue Dec 20, 2011 12:02 pm
So my 1990 NA has been stumbling some lately. Listening at the tailpipe, the drivers side seemed to be running fine but the passenger side was running rough and rich.
I check and there are no codes. Do the cylinder balance test and they all seem the same (removing any of them makes it run worse)
So, I replaced the passenger side O2 sensor (the drivers side was bad and I had purchased a pair, so I went ahead and swapped that). No change. I had plugs ready to go in, so I swapped those out. Drivers side all plugs look good, passenger side all cylinders running rich. Swap plugs, no change. Battery terminals were a little loose, so I replaced those. It SEEMED to get a LITTLE better, but I think that might have just been in my head.
Seems to run much better in the higher RPMs, dont know if its actually running that much better, or if the random stumble has less of an effect due to RPMs. At 3000 it seems OK, at 3500 its pretty good and over 4000 it seems to get a lot better. Putting it in a higher gear (so that it takes longer to get out of the low RPMs) really highlights the issue.
Any Ideas? CAM timing? do these cars ever jump timing? I need to get the 120K service done anyway, so that might be a good place to start.
