NA rb30 wont rev past 2250rpm
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
panama
hey there. ive got a na RB30 auto that wont rev past 2250 without dropping out. only happens when in gear and when the air is warm though.
the engine dies, and drops to 1500rpm but if you take your foot off, you can get it to build revs back up to 2250, but if you hold your foot flat and keep it there when it drops out, it goes in spurts. it doesnt ever cut out completely.
when its cold it runs like a dream. ive taken it to hungry jacks tonight and had no worries but i tried to take it for a test drive today at 10am and it was farked.
so now at this point ive done these things:
-checked fuel pressure, and its within specs outlined in haynes manual.
-ive tried a new afm
-its got a month old CAS
-it has a month old coil
-ive got a new ignition module.
-new dizzy cap and rotor
-ive opened and contact cleaned every block connector in the engine bay
-ive installed 2 new fuel filters in parallel.
-ive replaced the ecu
ive checked fault codes and they are 14, 23, 24, 31. nothing else
any other suggestions would really be appreciated as i'm at my wits end with this thing.
akwikz
Car: 1973 Skyline
Sounds like either the throttle position sensor (TPS) or the mass air sensor. Disconnecting either of those will cause that exact symptom so I would suggest checking there. First thing, completely disconnect the mass sensor and see if it makes a difference. If it makes it worse, then that connection is fine. If it makes no difference then I would try another mass sensor.
Now, the other option is the TPS. My experience has been that a bad wire on the TPS connector will cause the engine to "hit a wall" at 2200 rpm. Check these and see what happens.
Brian
Return to “GTR Forum / Skyline Forum”
