Nanaimo »
https://forums.nicoclub.com/nanaimo-u27234.html
Mon May 09, 2005 7:50 pm
For all who are recommending kits, I'm not in the US, so shipping for large car parts is prohibitively expensive, plus there's currency exchange fees, 14% tax, and 6% import duty. It actually ends up cheaper to get the parts custom made. (If someone knows of a 240 performance parts dealer in BC, please let me know)
Also, all of the intake kits I've seen put the filter in the stock location and run 80cm of tubing over the radiator instead of using 30cm to put the filter where the battery normally is.
Quote »Either way go for a 2.5-3" exhaust mandrel bent.[/quote]I have mentioned that this is a mostly stock NA KA24E, right? I'm not convinced I'd need anything bigger than 2.25.
Quote »if you are going to do it yourself, which you would probably be better off doing, if you know what you're doing.[/quote]I don't. Which is to say, I know how in theory, but have neither experience nor tools. My mechanics have both experience and tools.
Quote » Injen intake, ...$200, cold air extension, ... $120.[/quote]Plus a few hundred for taxes, duty, and shipping, plus annother few hundred to get it installed... and it costs just as much.
And it still would have the induction air running over the radiator, and worse yet the intake would be down low... It rains a LOT here. Water inside engines is very bad.
