Ive had 2.5 and 3in on non turbos KAs. 3 is too loud.
If you get an exhaust and on a budget get a megan racing header or ebay one. same thing. Have someone look over the welds before installing (Reason is they mass produce and sell cheap) get either a test pipe (fake cat) or a high flow cat. Next you want a resonator and muffler. Id suggest a BRM catback. They sound AMAZING. If you get a dual tip over the watermelon cannon this is what it is from maganflow (
http://www.ebay.com/itm/MagnaFlow-14815 ... 1585wt_804) I just bought another for my V8 project. I swear by them and looks stock enough you wont get harassed.
If your doing a NA build,
My setup for my daily:
Header
Cat delete (or high flow is a option)
catback. If you get a coffee can at the end your only asking for trouble.
~s13 KA24de
~2 S13 Exhaust cams. Turn the exhaust cam thats going in the intake side back (counterclock wise) 4 teeth.
~S14 intake manifold (has no secondary butterfly valve. (Or do ITBS
~Also Xcessive has a intake manifold forsale but id buy it if you start to get into pistons/turbo, etc.
~Taking the emmions stuff off only makes your engine bay look better and wont help HP wise. I did it bc well it looks like a freaking mess from the factory.
These cars are rated 155hp from nissan. In reality its around 124hpish to the crank.
Doing all the above will probably give you 10hp max.
If you want anymore info Ill answer anything, KA's are my specialty and know they better then my gf
Facebook @ Jeff Morgan. Pic of my old S13 is me.
