NA KA tune up! help!
hayato kazami
Car: 1997 240sx SE
hi guy!
is anyone have any good idea for tuning the KA24DE (NA)???other then, intake exhaust?? what else can i do???
by the way, i heard that if i could install a 10.5: 1 piston, it could add up 15hp, is it true?
I found some of it from ebay, but i am sure if those a right size, also, do i need do anything to the stock ECU in order to use that pistons?
Thank!
blackbeauty240
Car: cooking, fiddeling around with different cars
try bumping your timing up 2 or 3 degrees, but when you do this make sure to run a high grade of octane(93). pulleys, electric fan, cam, head work, I could go on and on and on so please use the search button, but before you try any major engine work(pistons, cam, head) please ask a credable mechanic.
SSS
High compression, ITB's, cams and a decent exhaust and engine management are your friend. Setup right you should be good for 200hp+ at the wheels.
hayato kazami
Car: 1997 240sx SE
do you think you guys can list the stuff i need for make up to 200hp+ at the wheels?
Exar-Kun
Car: 2005 350Z
sure:1. a lot of money
there you go.-chet
blackbeauty240
best response yet
Boostedka
Car: sex, and turbo charging rides
To get those kind of numbers isn't hard.
Here is a list that you can use.
MSD6A ignition & coil - no real power added, but cleans up the power band makes it more useable.
An underdrive pulley - UR pulley gave me 5 HP and 10lbs of torque can
An intake system, injen or hotshot. Go injen- sometimes hotshot has clearance issues.
Hotshot headers or better. Mated with a properly tuned exhaust you can see up to 20 HP.
FPR - fuel pressure regulator.
Test pipe - 2/14 -2 1/2 in (with tuned fuel) can see up 15HP to the wheels.
Advanced timing - play around by advancing you timing (on the dyno of course) with A/F meter ( I saw40 hp to wheels@full timing advance).
you can see some where between
165 plus to wheels before anything else.
maybe I can show you some old dyno sheets if I can find them.This is considering engine is in good condition and proper tuning has been done. Also remember the fuel injectors may start to give at this point.
Boostedka
Just a follow up. I did this on stock internals..
hayato kazami
Car: 1997 240sx SE
nice! thank you very much!
do you have any recommand sites?
