tonynalli »
https://forums.nicoclub.com/tonynalli-u14578.html
Thu Feb 16, 2006 5:50 pm
exaust. short ram intake, ud pullies, pullies for the ps, if you decide to remove the ac then more power to you, sohc pistons, port and polish, flywheel and drive shaft dont increase hp but reduces rotational mass, cams, header, down pipe, no cat, ecu upgrade, fuel system upgrade, custom throttle body, custom intake mani, or ITB's, proper dyno tuning, all plugs on the harness replaced if needed.not sure what its called but..there is an electrical system that eleviates the distributor and uses some form of coil packs..,.not sure what its called or how it functions im sure that and a few other things would kick the hp up almost to the 200's???
