Well, I've seen dynos of both, the hotshot one far outperforms the OBX one, and I hear about people having serious quality control issues with the OBX one all the time. What are you considering "design"? The fact that the inital pipes are connected together in the correct order for the firing order of the engine? Woo, big deal. They don't perform the same.ilsha wrote:the obx header is the same design as the hotshot header so i guess hotshot sucks to right InsanityInc?
like for example valve job and only port the exhaust side and just clean up the intake side don't port it.WDRacing wrote:As long as you don't ruin your port velocity you will make more power almost always. Your going to have to seriously remove some material to ruin the velocity. If your simply porting and polishing the casting imperfections you'll have small gains. The head will become more efficient.The key area to hit is under the valve seat.
With the skinny intake runners, which are extremely long, your velocity is not really a problem. The intake side shouldn't be polished to a mirror though, but the exhaust side should be as smooth as possible.
Gasket matching is also a simple DIY mod. Again you won't ruin the velocity if only matching the intake/exhaust to the head.
16.2? Man my auto s14 ran that with just a cone filter, exhaust, and open dif.McAdam wrote:yeah, you can really eff up a head with a home port and polish. It may flow better, but there is more to producing power than flow numbers. Turbulance, velocity, and a lot of other technical stuff. 16.2 tho? that is bad. i think my old 280zx would run that.
McAdam
