t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Mon Mar 11, 2013 12:20 pm
What's a normal mpg figure for an NA?
I'm pretty sure I'm getting something like 16 mpg with suburban driving and some highway, never floored it.
Last time I checked, ecu gave code 55. I didn't run the O2 diagnostic, but it has 2 new Bosch O2 sensors that have only been on for ~400 miles. The fuel filter, fuel lines, injectors (stock, new style w/ adapter kit), air filter, spark plugs, coolant temp sensor, knock sensor (and harness), and fuel temp sensor are all brand new. MAF was cleaned twice when I had it out with MAF cleaner, so were the throttle bodies and IACV. PVC valves and hoses are all brand new. AIV is intact, but EGR is deleted. It idles smooth right around 750-800.
When I went to get inspected for emissions in NJ, I failed. Turns out I had a leaky fuel injector o-ring, bad CTS and fuel temp sensor. When I took it back, I still failed, but it did alot better than the first time. I eventually passed using the vacuum line trick, but it doesn't explain why I'm still running a little rich. The only fuel system components that aren't new are the fuel pump, FPR, and fuel dampener (and ecu chip).
One other thing I'm just thinking of is that when I put the new spark plugs in, I don't think I ever gaped them. Would that affect gas mileage that much?
