z.Leinbach »
https://forums.nicoclub.com/z-leinbach-u254818.html
Thu May 18, 2017 6:18 pm
Well as the title suggests. I WILL be updating and upgrading my fuel system to handle... You guessed it ethanol, now i know these are pointless upgrades on a vehicle that doesnt have turbskies on it. Buuut this is a preemptive upgrade should i decide to either boost or go for very high compression, also to make the car just that much easier to put fuel in when ever im at of Ethanol content is higher then 10%.
Reason im considering this.
1 accessibility of any premium grade fuel no matter the ethanol content
2 new injectors can handle the Ethanol.
3. I am replacing the injectors and adding a tune so why not throw that into the mix
So what i would like to know is when upgrading to a e85 capable pump and flex fuel sensor. What flow size do i need to have for a NA that will have full single intake, block back exhaust at 2.5in lightweight pulley, and z1 performance clutch setup, and fully cleaned top end(lol doesnt hurt to mention).
