na flywheel on tt engine
camarokid
Car: 1986 Nissan 300zx
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
I was wondering if it was safe to use a lightweight na flywheel and performance clutch on a tt engine. I know the na flywheel is smaller so I thought maybe it would let the engine rev faster then a same weight tt flywheel.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
No, and the short answer is because the starter will not engage properly.
nissanfreak12
Car: 92 300zx 2+2 TT
Only way it would work is if you have an NA bell housing, but there is no point. You may save a pound at the most. Might as well get a lightweight flywheel.
camarokid
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
so if I have a na starter and na bellhousing it'll work? and I'm talking about both flywheels being lightweight. Since I've found a na flywheel thats 12.3 pounds with a stage 2 clutch for $260. figured I could get a tad better gas mileage and performance with a flywheel that has less area to spin.
elwesso
2007 BMW M Coupe
Basically what you want to do is match the N/A trans, flywheel and clutch.
camarokid
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
match? so theres no swapping bellhousings?
nissanfreak12
The biggest issue you will have is the clutch holding the power of the TT engine. Stage 2 may not be enough, you may have to go to stage 4+, and that i still going to be a big maybe.
NolimitZ32
Clutch and LWFW for $260? good luck with that.
