riu »
https://forums.nicoclub.com/riu-u41552.html
Wed Jul 05, 2006 5:53 pm
John, the power figure is optimistic, but i would definately want to reach it. I could settle for mid 400 hp range though, but it just feels like a lot of work to only gain 100-150 hp
I've already got a decent suspension set up on my Z32 already, but it could definately be better. Currently i'm running Tein SS coilovers and plan on getting a rear strut bar in a month or two. I plan on having ALL suspension work done with maybe the exception of a cage, before the VH goes in.
Is there a specific differential you recommend? I'm using my stock NA Z32 diff right now, i know its weaker than the TT but its still pretty strong as I understand it. What diff are you using on your VH Z32?
If you were doing this build... which you are... but if you were doing this build with my grocery list of parts i want to throw in there, what would you do different? Just the intake runners, exhaust manifold, different ecu? perhaps motec? If i really want the power should i just go your route and bore it to 5 litres?
Slow,Most of my research and plans have really been a variation of what John is already doing. I had wanted to do ITB and heard that John was doing them, so thats what i'm pretty much going to do. The JWT Pop, i'm pretty sure JWT makes a pop charger for the VH45, i just gotta get it to fit in there, most likely it'll sit where the Z32 intake sits, under the nose panel. As far as ECU, i'm just hearing the stock ECU is so damn powerful that with a romulator you have incredible flexibility with it. If i have to use something different then i will, its not something i've researched a lot yet.
thanks for the replies, this is really helping. I can't wait until i finalize the game plan and start the build
