NA 300ZX R200 Rear End Install....wtf....
Booztd 3
Car: 1990 Nissan 300ZX TT
Guys
I have an entire rear subframe out of a non-turbo 300ZX. I assumed that I would have everything I needed to put the R200 in, considering all the write-ups I can find all deal with installing J30 difs, not the 300zx dif.
So now on to the crappy part.....
The S14 I have has 6 bolt output shafts. There are 3 sets of 2 12mm bolts holding the axles to the output shafts.
The R200 rear end I have from the NA Z has 5 bolt output shafts. They are 14mm bolts.
So now I start thinking OK maybe I can swap output shafts between the difs, and my stock S14 axles will bolt up now. I get the output shafts out and immediately notice they are different. Not going to work
Now I am thinking lets just use the NA 300ZX axles, since they are the same spline hub, and they have the correct output flanges on for the R200.
I get the axles out and set them side by side, and immediately notice that the 300ZX axle lenght, and the S14 axle lenght are different, by quite a bit. I tried putting them in to see if the diff would fit up in there, no luck, they're too long.
What the heck do I need to make this rear end work?
Thanks
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
you need 5 bolt j30 axles, i have same setup in my s13
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
you could also see if you could get your hands on a set of output flanges from a super hicas S13 or j30 with the same flange pattern.
MagikDragon
super hicas s13's had a 6 blot flange
360_s13
Car: 92 240sx
i have the same problem i broke an axle on my super hicas s13 but mine has 5 bolt flange and it seems like every one of my friends has 6 bolt.
godzilla34
Car: nissan 240sx sr
j30's the way to go. i had to swap the rear cover to fit it on but i have j30 axles. =) fits like a glove
