N62 MAF questions
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Ok first off I looked it up in the search box as N62 Maf got couple results and did not search any more. Probably I'm posting it in a wrong section anyway, should be in general think. But then again it would be a upgrade part.
I was at the junkyard today to pick-up some parts that I needed and came across a J30 with the N62 MAF.
I have seen that these are kind-off pricey $50+ sometimes even $100.
is there any differences between N62 MAF as where it comes from 300zx or J30 for that matter?? It has an orange/silver sticker.
How do I check it to see if its good, I have a DVOM/Multimeter on hand. But what are the values for a good working MAF, and at which terminals?
Just want to check it to see if its good, dont know if I will need it or use it but its never bad to have something laying around that one day you might need. I will be buying turbo parts for the DE I have in the garage sometime soon, and I thought I might need this part too.
How much is too much for these MAF's, I was amazed when I paid for it $25.
eazye2000
Car: S13 KA-DET
I don't think there is a difference. I'm not sure though. I thought the N62, is an N62... Not sure about testing it.. Sorry... I would try to get it if you can get a good price on it.
placham
I all ready bough it have it at home.
Spent a total of $50. I bough the plastic trim that goes around shifter and radio with leather boot (which is like new), rubber boot/with metal ring that sits on floor around shifter, radio bracket with tray (for smaller radios not double din)just because I missed placed my old brackets, rubber clutch line(not sure as if this will work with what I got)because I have the style that loops around by the frame rail, and this one only had a line coming from top into valve/bleeder and straight to slave.(This would be temporary only, I want to get the steel/braided). Bunch of nuts and bolts. And the N62 MAF. the MAF costed me 29.99 with 2.99 core and that other crap 16.62. I say today was the day of days, looks like a good deal or should I say a steel.
MAF has a cover of dust over the top, clean inside and screen on both sides is flawless, no dents or rips.
placham
Looked around the forum in archives and found this thread zerothread?id=239874
Part number on my MAF is "22680-30p00" "a36-000 n62" looks like same as z32 MAF.
Now just need to check it, I know the FSM shows how to check KA24E Sohc MAF for resistance/ohms.
Oh yeah I have the wire and plug (4 wires)(white, black, orange, black/white)(terminals B,C,D,E)
DroptopDrifting
Car: 94 240sx limited edition se convertible
yeah, its the same maf as the z32 and anything under $100 is a steal. good buy bro. hook it up if you find another lol i'll send ya $50
spooled240
Car: kouki s14
man did i get raped, i paid 200 at autogator salvage yard your a bargain shopper
I heard you can test these with a volt meter and blowing through it as if you were blowing on a fire, then watch the continuity jump I may wrong..Mine worked perfectly without testing it.
These mafs usually last quite a while, I wouldn't worry too much about it not working, especially if you picked it up from a running car
and for wiring, go to jim wolf/tech support
neverlift
cant find the diagram I had for mine, just recall the chassis ground NEEDS to be grounded to the chassis, not wired to the ecu ground...
dont recall what I paid as it was before I went turbo and before I had the de motor even lol couldnt have been over 20 30 bux cause I'm cheap and the salvage guys love to see me pull up I get deals, civic drum to disc conversion= 60dollars big *** busted fmic 12 with a bov.... none the less good buy, now get it working
placham
I want to boost the DE I have. Just figured that I might need this MAF, when I saw it. I just couldnt let it waste there I had to bring it home . And when they rang up the bill I was like what you say . Your sure its only $49 for all that. I'm pretty sure its in good order car had like brand new air filter. So someone took care of the car. plus it was a J30 4 door sedan not 300zx sports car (that might of been moded and tweeked around with)
Otherwise it was only less $30 , I might get another one just incase, when I find one. And J30 are a lot easier to come by than a 300zx. I got a VLSD from J30 a while back.
I will try to get pictures of MAF, dont have dig-camera around just my cell phone, and if I will be able to post them.
things I bough for 50bucks [img][/img]MAF(dirty)[img][/img]MAF(clean)[img][/img]This is the best pic I can get of label(i'm using Helio Ocean to take pics, no dig-camera at home at this time)[img][/img]Dont want to post anymore pics, just for referance only. If they dont work let me know. Modified by placham at 4:15 PM 10/24/2007
Modified by placham at 4:17 PM 10/24/2007
Modified by placham at 4:19 PM 10/24/2007
Modified by placham at 4:22 PM 10/24/2007
Modified by placham at 4:23 PM 10/24/2007
