CA18Magic »
https://forums.nicoclub.com/ca18magic-u78512.html
Mon Jul 05, 2010 2:35 pm
Ok, so ive done search after search and cant come across a clear answer.
I know i'm clearly having maf issues with my stock j60 maf. I'm experiencing bogging, as if i stopped pressing on the throttle. Hard starts even though my fuel pressure is up. Runs fine for a bit, then sometimes throw a code 12 on the ecu (maf sensor). So, time to find a replacement. And coming across a replacement locally is near impossible. So i know so far that the N60 maf is a good replacement for the rb20. As long as you are only looking to stay around 300-350 hp, which is fine. I know it runs a little rich due to different input info but whatever. I can deal with that for now.
So what i'm trying to figure out, is the wiring for it. I know it cant be plug and play cuz ive read that the n60 maf has 5 wires and my j60 only has 4. Anyone have a reliable wiring guide somewhere? I can't find anything on it. Or are any of you running the N60 maf on your RB? Wiring help would be awesome, but drivablitly issues are also on my mind? I could set my fpr to stock pressure so that a little more fuel wont be so bad. LMK!
