Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Mon Sep 23, 2002 7:14 am
If you notice the ZEX kit is "not to be used for forced induction" and "not to be used with rising rate regulators" in other words it will max out your injectors too quick and blow things up if you run it in conjunction with boost. Get a NOS or NX kit (a wet kit) and you'll be MUCH safer. The dry kit is just dangerous especially on an ECU that's not tunned for NOS, the misfireing might be due to leaning out at lower RPM's, OR too much fuel (depending on how your plugs look). Either way the ZEX kit isn't a good idea if you want to run boost.
I'd suggest getting a new set of nitrous solonoids from NOS, a fogger, and some fuel line and converting to a wet system, that should slove most of your problems.
later,Paul
